Code P0354, car is shaking?
31,000 MILES • 4WD • AUTOMATIC
LOUISF42
The vehicle listed above is a hybrid.
The car shakes when applying gas or idle. Looks like a fuel pump shaking. P0354 code comes up with obd tool.
Apr 19, 2025 at 3:24 AM
  • 55,673 POSTS
All right! An easy one, the ignition coil on cylinder 4 is bad. I would replace it with a new one which should fix the problem, but you will need to clear the codes once the coil is replaced. Let us know if you need anything else.
Apr 20, 2025 at 4:44 AM
