P0345, p0349 Codes?
62,000 MILES • 5.0L • V8 • 2WD • MANUAL
5LUI1HDEZ5
Engine Misfiring
Apr 25, 2026 at 7:01 PM
AL514
  • 5,697 POSTS
Hello, did these fault codes come up after anything specific, such as an oil change? Both codes are setting for the same Camshaft position sensor. Bank 2 sensor A(probably the intake camshaft). Ill post some service info on the sensor and wiring diagrams so you can do some checks.
Apr 27, 2026 at 12:22 PM
AL514
  • 5,697 POSTS
We are still getting the new site's bugs worked out, so posting a wiring diagram right now isnt possible, but I would be happy to email you the wiring diagrams with testing instructions.
You are looking for one of the 2 Intake (sensor 1) camshaft position sensors. The intake cam position sensors have 3 wire connectors, while it looks like the exhaust camshaft position sensors are a 2 wire connectors. So that will help in locating the correct sensor.
For right now, you are looking for a 3 wire sensor, (Top Right Rear of Left (drivers side) cylinder head. The wire colors are-
*Pin 1 Violet with Green stripe (B+).
*Pin 2 Yellow with Blue Stripe (Signal).
*Pin 3 Yellow with Green stripe (sensor Ground). I can email the wiring diagrams anytime.
Apr 27, 2026 at 1:14 PM
