P0344 $7E8 Generic Camshaft Position Sensor A Circuit Intermittent Bank 1 or Single Sensor?
143,673 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
PAUL-82
  • 9 POSTS
Above is copied from my obd2 code scanner please help me find the location.
Jan 1, 2024 at 11:58 PM
  • 55,628 POSTS
The error code P0344 on your 2014 Ford Flex indicates an issue with the Camshaft Position Sensor A Circuit Intermittent in Bank 1 or a Single Sensor.
Here is the location of the sensors so you can check it out or see what needs to be done to fix the problem. Bank 1 is on the right side of the engine as you sit in the driver's seat. If the oil is clean and full and the sensors are okay the camshaft phaser will need to be changed out, which I will included as well if you want to see how the job is done. Check out the images (below). Let us know how it goes.
Jan 2, 2024 at 3:07 AM
PAUL-82
  • 9 POSTS
Above is copied from my obd2 scanner do I change out both camshaft position sensors
Jan 3, 2024 at 1:18 AM (Merged)
  • 55,628 POSTS
Did you check the engine oil? You can change both sensors if you want but to me it sounds more like the phaser is worn out or the oil is low or dirty. After changing the sensors clear the codes and let me know what happens.
Jan 3, 2024 at 1:53 AM
PAUL-82
  • 9 POSTS
Okay, I will have to go buy another sensor.
Jan 3, 2024 at 2:21 AM
  • 55,628 POSTS
How is the engine oil?
Jan 3, 2024 at 3:23 AM
PAUL-82
  • 9 POSTS
It had no oil when it turned off on me while on the highway it came to a slow stop. I just replaced the other camshaft position sensor. So, two new ones tried starting it and all it does is my starter just keeps clicking then it starts to smoke the starter is good put a new battery so whatever the starter turns might be seized.
Jan 4, 2024 at 7:14 AM
  • 55,628 POSTS
Yep, that will cause the codes. With no oil the engine might be seized. To tell for sure this guide can help us:
https://www.2carpros.com/articles/engine-seized-test
Please upload pictures or videos of the problem so we can see what's going on.
Jan 5, 2024 at 12:52 AM
PAUL-82
  • 9 POSTS
I'm home right now. I live in Fillmore, CA.
The time is 9:54-am right now I need to get ready and head over to the office where my car is.
Jan 5, 2024 at 1:55 AM
PAUL-82
  • 9 POSTS
Okay, I just got here, here are the videos.
Jan 5, 2024 at 5:12 AM
PAUL-82
  • 9 POSTS
There is 1.
Jan 5, 2024 at 5:16 AM
  • 55,628 POSTS
Looks like the battery is dead, I would remove it and take it to the auto parts store for testing. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Check out the images (below). Let us know what you find.
Jan 7, 2024 at 1:56 AM
PAUL-82
  • 9 POSTS
Well, I can crank it by hand but it's really hard to, so I'm assuming the motor needs to be rebuild.
Jan 7, 2024 at 2:25 PM
  • 55,628 POSTS
That could be, how is the battery?
Jan 8, 2024 at 1:30 AM
