p0343 code no spark at plug /motor stalled
2001 SATURN L300
182,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
01SATURN
I have replaced the timing belt it's in time new cam and crank sensors new ECM new starter new tcm I can't get spark at the plugs replace both coil packs nothing still have a 343 code and no spark any help would be great
Nov 18, 2015 at 11:08 PM
I attached a description of the code. you will need a scan tool to verify. it sounds like you have a wiring harness issue.
The Camshaft Position (CMP) sensor produces an AC voltage of different amplitude and frequency depending on the velocity of the camshaft in order for the ECM to determine the camshaft position. The CMP sensor detects a single tooth on the reluctor wheel. The ECM expects the signal wire to be near 5 volts when the reluctor wheel tooth passes the sensor and near 0 volts during the remainder of the reluctor wheel revolution. The ECM constantly monitors the CMP signal and expects to see a switch from low to high once every two crankshaft revolutions. The Camshaft Position (CMP) sensor is used to determine which of the two cylinders is on the firing stroke. With the CKP sensor and CMP sensor inputs the ECM can properly synchronize the ignition timing, fuel delivery and engine knock control. DTC P0343 will set if the ECM detects the CMP sensor signal voltage remains high for a calibrated number of camshaft revolutions.
DTC PARAMETERS
DTC P0343 will set if the ECM detects the CMP sensor signal voltage remains high for a 8 camshaft revolutions when:
Engine is cranking for at least 3 seconds
OR
Engine is running
Condition exists 2 or more times
Condition exists 1 or more seconds
DTC P0343 diagnostic runs continuously once the above conditions have been met.
P0343 is a (type B) DTC
DIAGNOSTIC AIDS
To locate an intermittent problem use the Scan tool to monitor CMP RESYNC COUNTER with engine cranking/running. If the counter toggles between 85 and 170, the crankshaft pulses correctly are being received.
If the CMP RESYNC COUNTER reads 0 counts, there is a low voltage condition present. If the CMP RESYNC COUNTER reads 255 counts, there is a high voltage condition present.
DTC P0343 can set due to an intermittent open or short to voltage in the CMP circuits.
Make sure the crankshaft position sensor circuit wires are clear of voltage interfering wires. Electromagnetic Interference (EMI) waves can alter the amplitude and frequency of the CMP signal and create invalid CMP pulses.
© 2015 ALLDATA LLC. All rights reserved. Terms and Conditions
Nov 22, 2015 at 1:02 AM
01SATURN
I did what you said. I now have spark at all 6 plugs but car still will not start. It is pushing flames fuel and smoke out the in take checked fuel pressure 46 psi rechecked the timing belt all marks line up pulled it to a shop gave 2 hours cost $183 car has ate my lunch and still will not run any help that makes my car run I will not forget who helped . I'm lost on this car
Nov 23, 2015 at 8:22 AM
