P0342 code
89,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
LISA DEMMON
Car has a new battery, new plugs, new camshaft sensor. It turns over but will not start. Still getting a p0342 code. Any ideas? This car is new to us and we out know any history behind its maintenance. It came with no battery and very wet inside. It now has a battery and car is dry inside and out.
Mar 9, 2017 at 3:11 AM
HMAC300
  • 48,601 POSTS
342 is cam sensor and may be reason not starting see picture it is for bank 1 which is intake unless this is a convertible and or supercharged. It may be a wiring or PCM issue as well, but sensors normally go bad first. it is the one marked 13.
Mar 9, 2017 at 4:21 AM
LES-G
Look at your camshaft chain. Mine was showing the same code turns out cam chain stretched and the guides had shattered common fault on mini.
Mar 23, 2018 at 8:21 PM
  • 55,548 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Mar 26, 2018 at 5:12 AM
