Did timing chain guides and tension-er's on my vehicle and put it all back together now it will start and run, has hesitation when I push the gas then revs up beautifully then idles good for five seconds then all of a sudden misses like crazy and shuts down blowing the PCM 30 amp fuse. It runs good for the first ten to twenty seconds after start up. Only code showing is the p0340 cam sensor code. Cam sensor has been replaced as well as all eight coils and plugs and the battery. Nothing that has been replaced has had any effect on the issue. I am wondering if this sounds like a wiring issue or if the timing is off a tooth and where would it be off? The only issue the vehicle had prior to the first tear down was the oil pickup and filter was clogged with what was left of the timing chain guides. Two tension-er's were replaced and the third one was still good. I am thinking the cams are off one tooth but would that cause the PCM to blow a fuse?
May 30, 2018 at 12:28 AM
