Code P0340, camshaft sensor location needed
127,000 MILES • 3.5L • 6 CYL • 4WD
OBEATA
  • 11 POSTS
I want to know the exact place where its camshaft sensor is located. since it is not at the back of the cylinder like every other mode. Please help.
Feb 3, 2019 at 9:14 PM
Good morning,
That is the only location for the sensor. I attached a general picture of the location. It has to be along where the camshaft turns to pick up the revolutions.from the cam.
Some possible issues for the code.
P0340
Descriptor
Probable Causes
Battery Voltage Low
Camshaft (Intake)
Camshaft Position (CMP) Sensor
Phase Circuit Open or Shorted
Starter Motor
Starting System Circuit
Feb 3, 2019 at 9:38 PM
OBEATA
  • 11 POSTS
Thanks Roy. from the car it has one each from each side at the front. there was a time the car came up with p1110 and it refers to those front ones. after fixing it it gave P0340,which indicates camshaft sensor. all the videos on YouTube shows it has been at the back of the cylinder for other truck, but this 2001 pathfinder 3.5L does not have any at the back, yet the car goes on and off while driving it. I am frustrated.
Feb 3, 2019 at 9:44 PM
I would not rule out a timing belt issue.
Codes never identify bad parts just failed systems.
I understand but I would get a scan tool and make sure there is a signal from the sensor to the PCM.
Feb 3, 2019 at 9:46 PM
OBEATA
  • 11 POSTS
The car use chains not belt.
Feb 3, 2019 at 9:48 PM
OBEATA
  • 11 POSTS
Got it, but they could still be worn and the crank and cam signals could be out of sync.
Feb 3, 2019 at 9:58 PM
OBEATA
  • 11 POSTS
Though the chain makes some noise, could it be the cause?
Feb 3, 2019 at 10:34 PM
Yes it could.
You need a scan tool that can read live data to see if that signal is not the same as the cranks sensor.
Feb 3, 2019 at 11:15 PM
OBEATA
  • 11 POSTS
After a while, I coupled the engine, crank it severally, it starts but goes off in few minutes and it takes serious cranking before it comes on again. I re-scanned and it is showing P1110, the P0340 had disappeared. what can I do?
Feb 4, 2019 at 2:22 AM
The 110 is also for the sensor.
You need a scan tool. If you do not have one then I suggest having someone check it for you.
P1110
Descriptor
Probable Causes
Crankshaft Position (CKP) Sensor
Signal Pick-Up Portion Of the Camshaft
Feb 4, 2019 at 5:08 AM
OBEATA
  • 11 POSTS
I have and Odb Ii and it is the tool that shows all these codes.
Feb 4, 2019 at 5:20 AM
Is it a code reader or an advanced scan tool that can read live data?
Feb 4, 2019 at 5:21 AM
OBEATA
  • 11 POSTS
I think it is a code reader. Can you suggest a better one? Please give me a name. thanks
Feb 4, 2019 at 10:39 PM
The advanced tools are expensive. They can run thousands of dollars.
Snap on, Tech 2, Autell, are among a few.
Feb 5, 2019 at 12:55 AM
OBEATA
  • 11 POSTS
Copy!
Feb 5, 2019 at 4:44 PM
OBEATA
  • 11 POSTS
But from what I heard and learnt, the 2001 Pathfinder do not have cam sensor at the back like others but only those two fixed at the front. any objection to this?
Feb 5, 2019 at 4:46 PM
Heard from who?
There needs to be a signal for the cam position for the PCM.
Feb 5, 2019 at 6:08 PM
OBEATA
  • 11 POSTS
Okay, if in doubt, please I need the exact location its fixed. I want to change it ASAP. Please help
Feb 5, 2019 at 8:37 PM
I sent you the picture of the location. Both Alldata and Mitchel show the same picture, same location.
Feb 6, 2019 at 5:51 AM
