Code P0335
2009 SUZUKI SX4
167 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
CALOBETO IBARRA
  • 25 POSTS
can you please help me with the wire diagram for sensors crank and cam please? I need the pinout I.
I can see the 5v reference and my ground, but I don't have or see my 12v in the ECM.
Thank you so much in advance.
Oct 12, 2021 at 9:53 AM
  • 110,240 POSTS
As far as the problem, it looks like you are on the right track. It deals with the CKP circuit A. What I did is this. First, I attached the wiring schematic for the entire powertrain control circuit. I highlighted the wires from the CKP and CMP to make it easier for you to trace. Additionally, I highlighted the CKP and CMP sensor in the schematic.
Next, I included the diagnostics related to the code. They follow the schematics and are specific to the P0335.
Here is a link you may find helpful when testing wiring:
I hope this helps. Let me know what you find or if you have other questions.
Take care.
See pics below. Note: The schematics were a few pages long. I had to cut each page in half to make them readable for you. I did overlap them so you can follow from one to the next. Also, pic 7 starts the diagnostics. Pics 4 and 6 contain the sensors in question.
Oct 12, 2021 at 12:40 PM
CALOBETO IBARRA
  • 25 POSTS
Update: so, I was doing a bypass test (test light connect to positive and tapping the signal wire with it) somehow the crankshaft position sensor woke up because now the RPMS gauge is working. but if I shut the car off the gauge stops what I find out that with the car idling if I tap or touch the Camshaft Sensor signal wire (back probe) the tachometer starts working and the car runs normal if I erase all the codes only the p0340 camshaft comes back I already changed the camshaft sensor.
Bypass test only worked for the crankshaft I can hear the relay activating, but when I did it for the camshaft, I didn't hear anything on the relay
Do you think is a short to ground?
thank you for your help.
Oct 18, 2021 at 2:01 AM
  • 110,240 POSTS
If you were probing with 12v, check to make sure there isn't corrosion or something causing excessive resistance. The sensors should only be getting a 5v reference. As far as a short to ground, that won't fix itself when you use the test light.
Let me know what you find.
Oct 18, 2021 at 10:27 AM
CALOBETO IBARRA
  • 25 POSTS
The sensor is getting 1.29 v.
Oct 18, 2021 at 12:58 PM
  • 110,240 POSTS
That should be 5v. Go to the ECM and check for corrosion, a pushed-in pin, a bent or broken pin, or anything that can cause a power issue.
Oct 18, 2021 at 2:03 PM
