Code P0304, Cylinder 4 Misfire?
180,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
THEHOLDER02
Hello all,
I have the truck listed above Silverado that is experiencing a rough idle and misfire. My mechanic buddy tried to troubleshoot the misfire but was unable to. We swapped out cylinder #4 coil pack with cylinder #1, same with wires and spark plug one at a time. Cleared the P0304 code. It is still showing P0304 #4 cylinder misfire. He sprayed some carburetor cleaner to make sure we didn't have a vacuum leak as well and he said it was good. Any other suggestions to try to troubleshoot or repair my issue? I have changed out all 8 spark plugs with new ones. I have read that next is probably a good idea to do a compression test on all the cylinders but I wanted to see if maybe we are missing anything before hand. Any suggestions would be greatly appreciated. Sorry forgot to say we did swap the #4 fuel injector with #1 and still did not change the misfire from cylinder #4 to cylinder #1.
Feb 13, 2023 at 3:15 AM
  • 110,248 POSTS
It certainly could be an issue with engine compression. However, have you tested the fuel injector for cylinder 4? If you have a dead miss it may not be getting fuel to that cylinder.
Here is a link that explains how to test an injector:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Also, disconnect the connector to see if there is any corrosion or other issue that can prevent a good connection.
Let me know what you find.
Feb 13, 2023 at 8:23 AM
