Code P0304?
158,740 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JGONZO2398
  • 375 POSTS
So, I got into my car in the parking garage after work today and it had a rough start with the check engine light flashing and the VSA light also came on. I scanned it and the above code showed up. I replaced my spark plugs and ignition coils last year in September, and I did my most recent oil change in the beginning of September this year. I’ve had a similar problem a couple years ago with similar codes and low oil is what caused it. I went to a nearby AutoZone and bought a quart of oil, topped it off and also disconnected and reconnected the cylinder 4 coil. This stopped the flashing check engine light and rough engine idle, but the same code remains. What can this be?
Nov 13, 2024 at 9:17 AM
  • 110,248 POSTS
If you resolved the cylinder misfire, the code needs to be cleared. Are you able to have that done? Also, it may eventually clear itself, but I can't tell you how many miles or starts it will take.
Nov 13, 2024 at 10:38 AM
JGONZO2398
  • 375 POSTS
I forgot to mention, the oil level was normal, that was just a measure I took because I had a similar issue in the past. I checked the spark plug and it looked fine, as well as the coil, so I left it as it was. I cleared the engine light for now so I will see if it returns.
Nov 13, 2024 at 10:58 AM
  • 110,248 POSTS
Thanks for the update. Let me know if it returns. Hopefully, it won't. LOL
Take care of yourself.
Nov 14, 2024 at 11:56 AM
JGONZO2398
  • 375 POSTS
Will do, I went ahead and replaced both the spark plug and ignition coil just to be sure.
Nov 14, 2024 at 2:23 PM
  • 110,248 POSTS
That was a good idea. Hopefully, it is resolved.
Nov 15, 2024 at 1:30 PM
