Code p0304?
220,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
DONMCKOWN
When changing rotor, I noticed play in the shaft though the rotor was tight. Is this normal? The problem started with a flashing SES, codes p0304, p0420, p0430, used cataclean, light went off, passed smog, light came back on code p0304. started have security issues- wouldn't start, changed fuel pump thinking that was the problem. changed connector to map and temp sensors. codes were p0174, p0304, p0420, p0430. changed plugs, wires, cap, rotor, and oil. code now down to p0304. trying to figure this out. truck starts every time, check engine light is always on, that's the only two things that are consistent. It seems like it doesn't start flashing until I have to decelerate and then reaccelerate without dropping a gear. stops flashing when I go below 1000rpms, lots of the time you can't feel it missing when its flashing. I tapped into the gas line just after the filter and sprayed cleaner thru the injectors then I changed the filter and the 02 sensor, still p0304.
Mar 28, 2024 at 7:20 AM
  • 110,248 POSTS
Since we know the problem is specific to cylinder 3, I would remove and inspect the spark plug to see if there is anything indicating a problem.
As far as the play in the distributor shaft, no that shouldn't be loose.
Keep in mind, a misfire isn't always caused by an ignition issue. It could be fuel-related or an internal engine fault as well. Since it is limited to one of the cylinders, I don't feel it is a fuel pressure issue or vacuum leak, but it could be related to the fuel injector.
Remove the spark plug and let me know what it looks like. If it looks good, the next thing to do is check compression. It has a lot of miles on it. If the compression is low, it can cause this issue as well.
Here is a link that explains how that is done:
You will need a compression tester, but most parts stores will lend one to you.
Mar 28, 2024 at 1:25 PM
DONMCKOWN
The plug is good and should be able to do compression test tomorrow. will let you know.
Mar 28, 2024 at 2:00 PM
  • 55,758 POSTS
Yep a compression test will help us can I ask if the engine makes a ticking noise?
Mar 30, 2024 at 3:34 AM
  • 55,758 POSTS
anything?
May 11, 2024 at 6:01 AM
