Code P0303
2005 HYUNDAI SONATA
160,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
CHRIS CALAMARI
I have been checking out this code and I have swapped out plugs, moved injectors and coils. ohmed out wiring under plenum, still get code. trying to tell if it is the ECM. I do not know where to go next.
Oct 17, 2017 at 6:17 AM
STEVE W.
  • 15,295 POSTS
Have you looked at compression or done a leak down test? Could be the result of low compression or a sticky/burnt valve. Toss a scope on the ignition and injector and see which one is dropping out and causing the misfire.
Oct 17, 2017 at 8:56 AM
CHRIS CALAMARI
Did compressed test and it is twenty pounds lower.
Oct 17, 2017 at 10:20 AM
  • 31,937 POSTS
do a wet test this will show if rings or valves are the main problem. if compression does not come up you have a valve issue to look at. also, just make sure that you do not have a vacuum leak as well. check these first.
Oct 17, 2017 at 10:23 AM
STEVE W.
  • 15,295 POSTS
Yep, as MHP says, do a wet test. 20 psi is enough to cause a misfire monitor to trip. Hopefully the wet test shows the same number. Easier to pull just the head and deal with valves than pulling the bottom end apart to play with the rings.
Oct 17, 2017 at 1:45 PM
CHRIS CALAMARI
Complete dry and wet compression test #1-193/235 #3-183/245 #5-190/255 #2-195/195 #4-195/210 #6-195/195. so I guess I can say the rings are gone?
Oct 18, 2017 at 1:01 AM
STEVE W.
  • 15,295 POSTS
Nope, you have a valve issue on #2 and #6. With the firing order on that engine and the slightly lower compression in three the ECM is tossing out the P0303 because the crank is slowed by #2 and #3 then speeds up when #4 fires and it thinks #3 is the issue.
Do a leak down test and see where the leak is.
Oct 18, 2017 at 2:13 AM
CHRIS CALAMARI
I am retired and do not have the equipment any longer at my disposal to preform a leak down test. is there another way to check?
Oct 18, 2017 at 2:48 AM
STEVE W.
  • 15,295 POSTS
Not as easily. If you have a compressor the tool itself can be borrowed from many parts stores.
Oct 18, 2017 at 6:52 AM
