Code P0303
125,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
JPHILLIPS120V
pulling code p0303, replaced distributor and rotor, spark plugs and wires, crankshaft position sensor, fuel pump pressure tested at 55 PSI, replaced 02 sensor on bank 1 number 2. What else can I check?
Jan 22, 2021 at 12:29 PM
SEVAG P
  • 405 POSTS
You have misfire at cylinder 3 refer to fault code p0303,that spark can be the problem, injector or low compression in that cylinder.
use our guide how to repair misfire.
Check for injector pulse.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Check ignition spark at cylinder 3.
If you have good blue spark and the injector is good, then you must check the compression of that cylinder and compare with others.
Let us know what happens with you.
Jan 23, 2021 at 1:30 AM
