Code P0301 cylinder one misfire
2008 CHRYSLER SEBRING
172,463 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CHAVISPIERRE
  • 7 POSTS
My car is throwing a cylinder 1 misfire and I have already done new coils, plugs, O2 sensor, switched around injectors, new cam and crank sensors and still getting the same code. I don’t know what else to do. any ideas?
Apr 29, 2020 at 10:12 AM
Good evening,
The first thing I would do is a compression test to be sure the engine has no internal issues.
I would also do fuel pressure test as well to be sure sufficient fuel is at the rail for the injectors.
Did you verify spark to number 1 cylinder or all of them?
Apr 29, 2020 at 10:52 AM
CHAVISPIERRE
  • 7 POSTS
Yes I’ve done all of that and it's fine.
May 6, 2020 at 8:10 AM
CHAVISPIERRE
  • 7 POSTS
Have been doing some research and it’s saying it maybe the throttle position sensor or the PCM is bad.
May 6, 2020 at 8:11 AM
What were the exact results of the tests I asked? Fine to you may not be fine. I need that information.
No to both. Neither one has anything to do with the code.
May 6, 2020 at 8:50 AM
