P0300p error code
2002 BUICK LESABRE
196,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
MNVILLAGEGIRL
  • 5 POSTS
My car is having issues accelerating throwing a random misfire code. The coil packs and module have been replaced, the fuel pressure regulator, the spark plugs and wires. I am at a loss for why it still throws the misfire code.
Aug 20, 2016 at 8:49 AM
SATURNTECH9
  • 30,869 POSTS
So is the miss fire only under load? Or at idle?
Aug 20, 2016 at 10:19 AM
MNVILLAGEGIRL
  • 5 POSTS
It misfires while driving and idling.
Aug 20, 2016 at 10:30 AM
SATURNTECH9
  • 30,869 POSTS
Do you have a scan tool that shows live miss fire data like which cylinder is missing? Does it feel like there is a cylinder not firing at all?
Aug 20, 2016 at 11:46 AM
MNVILLAGEGIRL
  • 5 POSTS
I have a scan tool, but it gives the random misfire code. It does not give a cylinder number.
Aug 20, 2016 at 12:12 PM
SATURNTECH9
  • 30,869 POSTS
The more advanced scan tool will show you which cylinders are miss firing. At least on the GM cars. Does it feel like a cylinder is not firing at all?
Aug 20, 2016 at 12:29 PM
MNVILLAGEGIRL
  • 5 POSTS
No, it feels very intermittent. Not like one cylinder is not firing.
Aug 20, 2016 at 12:48 PM
MNVILLAGEGIRL
  • 5 POSTS
I took it to a repair shop and they could not deduce why it was misfiring.
Aug 20, 2016 at 12:49 PM
SATURNTECH9
  • 30,869 POSTS
Could they tell you which cylinders were miss firing? the scan I have shows current miss fire count and the history of each cylinder miss fire counts. That would tell which cylinders were missing so you could swap parts from cylinder to cylinder to see if the miss fire moves .
Aug 20, 2016 at 12:56 PM
