Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Lesabre
Trouble Codes
P Codes (Powertrain)
P0300 - P0399
P0300
P0300 trouble code
2002 BUICK LESABRE
200,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
FARMERJACK
MEMBER
1 POST
I have a p0300 trouble code with flashing check engine light and engine misfiring badly.
Oct 24, 2019 at 1:34 AM
Experienced Mechanic
Good morning,
I would start by performing a compression test to make sure there is no internal damage to the motor.
How old are the tune-up parts?
I would also check the fuel pressure as well to be sure the proper amount of fuel is being sent to the engine.
Image (Click to enlarge)
Oct 24, 2019 at 1:54 AM
FARMERJACK
MEMBER
1 POST
I replaced the ignition control module and that fixed the P0300 trouble code and misfire. thank you.
Oct 28, 2019 at 5:11 AM
ASEMASTER6371 is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
