P0300 code
115,000 MILES • V6 • AUTOMATIC
MOMMABEAR34
  • 8 POSTS
We have changed all plugs and wires, ignition coils (and all wires are ran correctly), and added treatment to the fuel to clean the injectors. It is still misfiring. Symptoms are rough idle and occasional stalling when put in gear, slow acceleration, and engine running loud and rough (which is not usual for the vehicle). What are we missing?
May 16, 2019 at 12:31 AM
Hi Mommabear,
Have you checked you actual fuel pressure? Two things come to mind with the fuel, first you have low fuel pressure from the pump. You test this by putting a fuel gauge on the rail and see what the pressure actually is. Second, your fuel pressure regulator is faulty and your fuel volume being delivered to the injectors is not sufficient.
Next is unmetered air is coming into the cylinders. This means you have an air leak past the MAF sensor.
The way to determine which of these it could be is to monitor the o2 sensor data and see what vehicle is actually doing. Is rich or lean. I am going to guess it is lean but remember this P0300 means that different cylinders are misfiring at different times. So it is something that effects all cylinders and not just one. That means most likely it is either air or fuel.
May 16, 2019 at 5:27 AM
MOMMABEAR34
  • 8 POSTS
Kasekenny1, thanks for the response.
We have not tested the fuel pressure as we don't have a gauge to test it, or to test anything really. When the car is running, we do smell a fuel smell like it is getting fuel but it isn't all burning off due to the misfiring. Someone suggested checking the valve cover gasket to see if it is leaking oil and if so oil could be getting down where the spark plugs are causing the misfire? Also, I was worried about the EGR valve and an O2 sensor as well.
May 16, 2019 at 5:51 AM
Okay. So we may be able to assume fuel pressure is okay but that does not eliminate the regulator nor the air leak past the MAF sensor.
As for oil leaking down on the spark plugs, that could cause it but that more than likely is going to cause a specific cylinder misfire not a multi cylinder misfire like you have. Remember P0300 codes are meaning that the PCM is seeing different cylinders misfiring at different times. That means a cylinder will misfire and then the same cylinder on the next compression stroke, it will not misfire but another one will and so on.
That means we have something wrong that effects all cylinders. The way we need to diagnose this so we are not guessing at parts is to monitor the short term fuel trim in the PCM and see what it is saying. If it is lean we may have a fuel issue or air leak issue. If it is rich then we have a spark issue. Once we know this info we can move onto the next step but at least we know whether we are chasing a lean condition or a rich.
You can go ahead and replace a lot of these parts in hopes that it fixes it but if they don't it would have been cheaper to have it diagnosed.
May 16, 2019 at 7:23 AM
MOMMABEAR34
  • 8 POSTS
Okay, so in layman's terms, how do I do that?
May 16, 2019 at 7:34 AM
You need a scan tool in order to read what the sensor is saying. I know you mentioned you don't have a gauge to test fuel pressure or anything so I am assuming you don't have a scan tool? If not, I would suggest getting one or taking it to someone who can look at this stuff.
I know that may not be the answer you want but if we don't see what the engine is doing based on the sensors then we are just guessing.
Here is a guide that you can test the air leak or vacuum leak portion of this:
If you find no air leaks past the MAF sensor here is a guide that talks about the MAF sensor itself and how you can clean it. If this is sending bad info then the PCM will over-fuel the engine causing a misfire.
https://www.2carpros.com/articles/mass-air-flow-service
Here are some other guides that will go through some basic things to check as well:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
May 16, 2019 at 8:06 AM
MOMMABEAR34
  • 8 POSTS
Okay. Thanks for explaining that for me! I am not that great with car lingo. So, this may be another stupid question, but a scan tool, is that like the code reader AutoZone uses to read the fault codes when the engine light is on, or is there a different one?
May 16, 2019 at 8:32 AM
MOMMABEAR34
  • 8 POSTS
Are you talking about an OBD scanner?
May 16, 2019 at 8:36 AM
Yes. OBD scanners but just be careful because some only read codes and do not let you monitor live data.
Someone actual just reported that the Autel AL329 from Walmart was not bad and pretty cheap for what you can do.
I am not recommending this but just make sure if you are going to look into buying one that it not only reads codes but can look at freeze frame data and live data.
May 16, 2019 at 8:40 AM
MOMMABEAR34
  • 8 POSTS
Okay. I will do that. Do you know what the price range is by chance?
May 16, 2019 at 8:42 AM
MOMMABEAR34
  • 8 POSTS
I circled what I am thinking would be what we would need it to do. Is that correct? It is a Autophix Code Reader OM126.
May 16, 2019 at 9:18 AM
The one I mentioned is about $50.00. They range from about fifty dollars to hundreds or thousands. Clearly, you don't need the higher priced ones if you are just looking to read sensors and stuff.
If you get one, just start with sending me the short term fuel trim for both bank 1 and 2 and we can go from there. Thanks
May 16, 2019 at 9:20 AM
MOMMABEAR34
  • 8 POSTS
I will. It will probably be next week before we can get one but I will post them when I get them. Thanks!
May 16, 2019 at 9:22 AM
Sounds great. Thanks.
May 16, 2019 at 9:41 AM
