Code P0300, running really rough?
132,270 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JAEDAV
  • 22 POSTS
Today I replaced the spark plugs in the car and replaced the driver side valve cover gasket. I did use dielectric grease on all the coils and plugs and noticed once I started the car it was running really rough. I pulled the plugs on the coils to narrow down which ones were causing the issue and it’s the two back coils on the driver side. I swapped them around to see if it would follow the coil and it stayed at those two connectors.
Apr 6, 2023 at 12:11 PM
JAEDAV
  • 22 POSTS
I had the connectors mixed up.
Apr 7, 2023 at 1:43 AM
  • 55,746 POSTS
Sorry we couldn't get to you sooner. Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Apr 7, 2023 at 3:59 AM
