P0300 code?
177,687 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JSITORIUS
I have replaced both plugs and coil packs and 1 o2 sensor and my Durango still won't idle in gear but does fine going down the road.
Aug 8, 2025 at 9:00 AM
  • 55,583 POSTS
Yep, the random misfire code, these are caused by a vacuum leak most of the time, especially with the rough idle. Here is a video to help you find the leak:
https://www.youtube.com/watch?v=LRKWV4Are5c&t
Also, can I ask if there is an exhaust leak? This can cause the issue as well. Can you upload a short video of the engine idling so I can see? This would help.
Aug 9, 2025 at 2:52 AM
JSITORIUS
There is no exhaust leak and I will try to get you a video
Aug 9, 2025 at 7:09 AM
JSITORIUS
Hope this helps
Aug 9, 2025 at 9:17 AM
  • 55,583 POSTS
That was one of the better videos, thank you. I would clean the throttle body, this guide can help. Please check the images below as well.
Also, lets use a scanner to check the LT trim an ST trim to see what the computer is doing. We may have a weak MAP sensor. I would still try the smoke machine for the vacuum leak, sometimes the spray misses the leak. Read the guide completely before you begin. Please upload a video of the throttle body condition :) Check out the images (below). Let us know how it goes
Aug 10, 2025 at 11:31 AM
