P0300 why would a car only have this code?
102,000 MILES • 4 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Very minor idle stumble but overall smooth. why would a car only have this code?
Aug 21, 2022 at 7:01 AM
  • 110,248 POSTS
A P0300 indicates a random misfire. This can be caused by a few things. Since you indicated it runs good other than a minor stumble at idle, my first suspect would be an engine vacuum leak or the need for a tune-up.
Has the vehicle been tuned up with new spark plugs recently? It should be done by 100K. If it has, then I need you to check for engine vacuum leaks. Here is a link that explains how to do it:
Aug 21, 2022 at 1:46 PM
