I got a P0300 code on my car. It is a 4 door hatchback. My check engine light blinks along with the Hold button. In the past 6 months i have replaced the following:
Battery
Battery Terminals
Fuel injection cleaner when filling-up, a full tank of gas
Engine coolant thermostat
Camshaft position sensor
Ignition coil pack
Spark plugs and wires
Fuel Pump Relay Switch
Air cleaner intake hose with sensor
EGR valve with gasket
Serpentine Belt
Fuel Pump
Fuel injectors
Throttle position sensor and you cleaned the throttle body
Battery
Battery Terminals
Ignition coil pack
Serpentine Belt
Fuel Pump
Fuel injectors
Aug 2, 2019 at 3:26 PM
