Check engine light on, code P0256
165,900 MILES • V6 • 2WD • AUTOMATIC
HD2424
  • 190 POSTS
I was driving home, and the A/C wasn’t working too good. I had a check engine light turn on with p0256. It started to overheat, I pulled over immediately. Could it possibly be the fan clutch? Please provide how I should proceed.
Thanks
Apr 5, 2022 at 8:00 AM
  • 55,721 POSTS
This sounds like two separate problems, the code P0256 Injection Pump Fuel Metering Control B Malfunction (Cam/Rotor/Injector) which I have seen the fuel pump that is going out can cause the issue because the computer can control the fuel pressure but to be sure here is how to check the fuel pressure in general with specific instruction in the diagrams below. Please re-post the overheating and A/C issue which should be related.
Fuel Pressure (Key "on", Engine "off") .................... 345-395 kpa (50-57 psi)
Apr 6, 2022 at 3:19 AM
  • 55,721 POSTS
Here is how you can change the fuel pump out in general with a guide below to show you how on your car:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Apr 6, 2022 at 3:25 AM
HD2424
  • 190 POSTS
Okay, will do. I got fan problem fixed, it was a bad relay.
Apr 6, 2022 at 3:58 AM
HD2424
  • 190 POSTS
I’ll be checking fuel pressure today.
Thanks for the help.
  • 55,721 POSTS
Nice work, let me know on the code P0256 problem.
Apr 6, 2022 at 4:47 AM
HD2424
  • 190 POSTS
Will do.
Apr 6, 2022 at 7:50 AM
HD2424
  • 190 POSTS
Update: fuel pressure below spec got new fuel pump ordered. thanks for the help.
Apr 6, 2022 at 10:46 PM
