Code p0240
160,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
DIGGOD1
replaced catalytic converter and both o2 sensor still have p0420.
Nov 4, 2021 at 2:37 AM
  • 110,248 POSTS
The code simply indicates the converter is no longer doing its job. Did you reset or clear the code? It should reset itself after three consecutive ignition cycles without a problem. Are there any other codes stored?
Since everything is new, we may need to confirm the sensors are working properly. There could be a wiring issue.
Take a look through this link. It explains what to test.
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
Let me know if you have a live data scanner and if there are any other codes stored.
Nov 4, 2021 at 12:45 PM
