Codes P0173, P0170, P0171, and P0174?
197,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
IBINIB
  • 15 POSTS
I have a vacuum leak! The exhaust system shakes and rattles, but I don't hear anything on the cat! I have checked everywhere hoses, intake manifold, PVC, throttle body and all sensors. Fuel pump and brake booster. The vacuum test reads at 10 I've tested injectors for power and any signs of leaks. Replaced the O-rings, I recently replaced 3 O2 sensors B1-S1 B1-S2 and B2-S2.
I have attached this freeze frame data.
Please help.
Mark
Oct 3, 2022 at 2:59 AM
  • 55,616 POSTS
I don't see the freeze frame data, but these codes can be caused by an exhaust leak as well.
here are guides to help us fix the problem:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
And follow this guide when the engine is cold:
Oct 3, 2022 at 9:07 AM
IBINIB
  • 15 POSTS
I will resend the freeze frame data.
Oct 3, 2022 at 9:49 AM
  • 55,616 POSTS
If the exhaust system is not leaking and no intake leaks it looks like from these reading the MAF sensor needs to be replaced. I would get a new one and not try to clean the sensor because it is too far gone. Here is the location of the sensor in the images below. Check out the images (below). Please let us know what happens. Clear the codes after the repair.
Oct 4, 2022 at 6:55 AM
IBINIB
  • 15 POSTS
Yes, you nailed it.
Oct 4, 2022 at 8:44 AM
  • 55,616 POSTS
Good to hear, please use 2CarPros anytime we are here to help. Can you please leave us a rating? (Copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Oct 5, 2022 at 9:36 AM
