Code P0171 lean code at idle?
95,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
JACK1999
I have attached some live data and a freeze frame when the lean code was set. Although the DTC is a lean code the a/f precat sensor and postcat o2 sensor seem to show a rich situation. I may be misinterpreting the data. Hope you can help. I have attached the data.
Apr 2, 2023 at 3:32 PM
  • 55,709 POSTS
I don't see the data images uploads can take a few seconds so be patient. Can I ask how the engine is running? A misfire might cause this problem. Also, I would check for vacuum leaks.
Here is a guide to help but only use it with the engine cold:
Also, this guide can help as well:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Please go over these guides and report back.
Apr 3, 2023 at 4:45 AM
