P0171 what could be causing this?
AUTOMATIC
FARR_2007
  • 93 POSTS
I’m getting a p0171 code what could be causing this and what do I need to get to fix it
Oct 2, 2026 at 6:57 AM
STEVE W.
  • 15,418 POSTS
P0171 is a Lean on bank 1 code. There are many possible causes. A vacuum leak, cracked intake gasket, injector problem, low fuel pressure, even an exhaust leak. Takes some testing to figure out where the issue is. First thing would be to look at the actual fuel trims and the O2 sensor voltages and see if the code is from something like a bad sensor of from a leak. However there isn't a simple fix. You can look at this and see if the testing helps to locate the problem -
https://2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers/
Oct 3, 2026 at 6:49 PM
BENNETTLYLE
  • 14 POSTS
I'd agree with checking the fuel trims before replacing anything.
I've been using an ANCEL FX2000 for about 4–5 years, mostly for basic diagnostics and helping customers track down car problems. One thing I've learned is that the trouble code alone doesn't always tell you what's actually wrong. Looking at the live data can save a lot of guessing.
For your P0171, I'd start by checking the STFT and LTFT with the engine warmed up, both at idle and around 2,500 RPM.
If the trims are much more positive at idle and improve when you raise the RPM, I'd be looking for a possible vacuum leak. If they stay high at both, fuel delivery or MAF readings would be worth checking next.
Not saying that's definitely your problem, but those numbers should help narrow things down before you start buying parts.
Nov 1, 2026 at 11:51 PM
  • 55,746 POSTS
I have seen a bad MAF sensor cause this issue. Also, please go over the guide above.
Nov 2, 2026 at 7:29 AM
