P0146 Error Code?
58,000 MILES • 4 CYL • 2WD • AUTOMATIC
TZAN
Few weeks ago, my service engine soon light came on. Brought it to the mechanic and found it was the P0146 error code. Found and replace a faulty oxygen sensor and rear cat converter with flex pipe. They also checked the wiring harness and found no
problem. While driving the car, the service engine soon light came back on and is still on. My mechanic suspects the ECM module. Is there any way to verify this and how do I fix this issue. Thanks
Jul 10, 2025 at 11:37 AM
MECHTRIX
  • 592 POSTS
First thing id do is.. ..maybe call around your area and see if there's a shop near you that has a good bi directional scan tool its able to check more than a regular scan tool including the ECM and all of the modules and individual sensors and other parts and test deeply ..activate de activate devices ..its a vary powerful way to analyze the problem often times it can find and test the suspected part or parts re write instructions to modules and the ECM and save you lots of time and money ..that said ..the ECM is pretty tough they're harder to break then people think built really well and designed to last many years and usually do" most times the life of the car... hope this answered some of your questions and "good luck ".
Jul 10, 2025 at 12:04 PM
MECHTRIX
  • 592 POSTS
Also a side note ..maybe ask the mechanic that changed the 02 sensor witch sensor he changed because that code po146 is specifically for a sensor that has lost communication specifically on bank 1 sensor 3 ..id recheck the connection there but id also still have it re scanned with a bi directional scan tool.
Jul 10, 2025 at 2:44 PM
