Code p0133, O2 sensor bank 1 sensor 1 slow response?
230,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
YAZIDAN
  • 141 POSTS
I have a p0133 code. O2 sensor bank1 sensor 1 slow response. What are the causes. where to start diagnosing?
Thank you
Apr 16, 2024 at 7:37 AM
  • 110,248 POSTS
The code indicates a slow response from the sensor. In most cases, the sensor itself is faulty and needs to be replaced.
However, I attached information below for you. It explains how the circuit works and the diagnostics specific to this code.
Let me know if this helps.
joe
Apr 16, 2024 at 1:14 PM
  • 55,709 POSTS
Here is the location of the bank 1 sensor 1 which could be telling you the primary catalytic converter might be going bad, clogged. Check out the images (below). Please let us know what happens.
Apr 16, 2024 at 1:55 PM
YAZIDAN
  • 141 POSTS
The code is intermittent does this change in diagnosis?
Apr 17, 2024 at 12:36 PM
  • 55,709 POSTS
Did you swap the sensor out? If so and the codes is still there I would still check the condition of the catalytic converter. The oxygen sensor is not switching because the exhaust cannot flow correctly.
Apr 18, 2024 at 3:10 AM
YAZIDAN
  • 141 POSTS
no, I did not replace the oxygen sensor. also, what I noticed is that the MAF sensor g/s at idle is low 1.4 g/s and fuel trim at 7%.
Apr 18, 2024 at 5:17 AM
  • 55,709 POSTS
That might be normal. can I ask what you are comparing the MAF sensor reads too? Also is the fuel trim long or short? You can try a MAF sensor to see if it helps, also can I ask how the power output of the engine is, low or normal?
Apr 19, 2024 at 2:44 AM
YAZIDAN
  • 141 POSTS
sorry for the delayed response.
1.what i heard MAF sensor reading at idle should be more than the engine displacement.so it should be more than 1.8g/s.
2. total fuel trim
3.engine power is good
Apr 24, 2024 at 9:29 AM
  • 55,709 POSTS
Okay, I would replace the oxygen sensor and then clear the codes to see what happens.
Apr 25, 2024 at 2:52 AM
