p0133
150,000 MILES
YOURGURLKATT
  • 5 POSTS
Had the oil changed and a few days later check engine light came on with code p0133 ( Oxygen Sensor Circuit Slow Response (Bank1, Sensor1). Could somethinghave been bumped or jarred during the oil change or do I need to have the o2 sensor changed? There are no engine running differences. Everything is the same as it was before light coming on.
Apr 27, 2013 at 7:13 AM
JDL
  • 16,098 POSTS
How long since a tune-up? 02 sensors are part of a tune-up. You can check the sensor/s make sure it isn't unplugged.
Apr 27, 2013 at 7:20 AM
YOURGURLKATT
  • 5 POSTS
Last tune-up about 30,000 miles ago.
Apr 27, 2013 at 7:23 AM
YOURGURLKATT
  • 5 POSTS
Where are the sensors located?
Apr 27, 2013 at 7:26 AM
JDL
  • 16,098 POSTS
Some possibilities for that code. exhaust leak--faulty sensor--faulty wiring circuit or connector.
Apr 27, 2013 at 7:27 AM
JDL
  • 16,098 POSTS
The 02 sensors are in the exhaust. The exact location may depend on litre size of engine. Bank 1 sensor 1 should be before cat converter.
Apr 27, 2013 at 7:31 AM
YOURGURLKATT
  • 5 POSTS
OK, I'll check all that. Thanks. :-)
Apr 27, 2013 at 8:32 AM
JDL
  • 16,098 POSTS
Let us know what you find.
Apr 28, 2013 at 1:47 AM
YOURGURLKATT
  • 5 POSTS
Checked the front sensor, wiggled it around a little, disconnected battery to reset check engine light, and it hasn't relit yet. Guess it was loose. Thanks for the prompt responses to my question.
Apr 29, 2013 at 1:17 PM
JDL
  • 16,098 POSTS
Hey, no problem. have a good day.
Apr 29, 2013 at 11:16 PM
