Codes p0121 and p0507 hard shift to drive,surge without acceleration,high idle
120,000 MILES • V8 • 2WD • AUTOMATIC
YAIYR
  • 7 POSTS
high rpm's, hard shift into drive and reverse, car coast on its own 40 to 50 mph. cleaned throttle body, changed TPS and idle control valve, new mass air flow sensor.
Oct 5, 2019 at 12:38 PM
Good morning,
I posted the description below that has some diagnostic aids to check. I also attached a flow chart. It could still be the throttle body as well.
I also posted the flow chart for the TPS as well.
This could be a bad throttle body. The bore for the idle air control may be carboned up holding it wide open.
CIRCUIT DESCRIPTION
The Idle Air Control (IAC) valve is located in the throttle body. The IAC valve consists of a movable pintle, driven by a gear attached to an electric motor called a stepper motor. The IAC valve motor is a 2-phase bi-polar permanent magnet stepper motor that is capable of highly accurate rotation, or movement, every time the polarity of a winding is changed. This change in polarity can be seen when observing a test lamp connected between ground or B+ and an IAC valve circuit while the Powertrain Control Module (PCM) is attempting to change engine RPM. The test lamp will flash on or off each time the polarity is changed. The PCM does not use a physical sensor to determine IAC pintle position, but uses a predicted number of counts, one count represents one change in polarity which equals one step of the stepper motor. The PCM counts the steps that have been commanded in order to determine the IAC pintle position. The PCM uses the IAC valve to control engine idle speed by changing the pintle position in the idle air passage of the throttle body. This varies the air flow around the throttle plate when the throttle is closed. In order to determine the desired position of the IAC pintle at idle or during deceleration, the PCM refers to the following inputs:
The engine RPM
The battery voltage
The air temperature
The engine coolant temperature
The throttle position sensor angle
The engine load
The vehicle speed
When the ignition key is turned OFF after an ignition cycle, the PCM will first seat the IAC pintle in the air bypass bore, and then retract the pintle a predetermined amount of counts in order to allow the proper amount of air to bypass the throttle plate for engine start-up. This procedure is known as an IAC Reset.
CONDITIONS FOR RUNNING THE DTC
DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0117, P0118, P0121, P0122, P0123, P0125, P0201, P0202, P0203, P0204, P0205, P0206, P0207, P0208, P0335, P0336, P0340, P0341, P0385, P0386, P0401, P0403, P0404, P0405, P0440, P0442, P0443, P0446, P0449, P1106, P1107, P1111, P1112, P1114, P1115, P1121, P1122, P1336, P1372, P1404, or P1441 are not set.
The Engine Coolant Temperature (ECT) is greater than -40°C (-40°F).
The Intake Air Temperature (IAT) is greater than -18°C (-1°F).
The ignition voltage is between 10.5-16 volts.
The Barometric Pressure (BARO) is greater than 65 kPa.
The engine run time greater than 40 seconds.
The transmission gear state has not changed for 3 seconds.
The Torque Converter Clutch (TCC) state has not changed in 3 seconds.
The TPS less than 1.5 percent.
The spark advance is less than 12.39 degrees.
The spark retard is greater than -13.79 degrees.
The Vehicle Speed Sensor (VSS) is less than 3 km/h (1.9mph).
The above conditions are present for 3 seconds.
CONDITIONS FOR SETTING THE DTC
The actual engine speed is 100 RPM greater than the desired engine speed.
The above enabling criteria must be met and fail the diagnostic 3 consecutive times to set this DTC.
ACTION TAKEN WHEN THE DTC SETS
The control module illuminates the Malfunction Indicator Lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
The control module turns OFF the Malfunction Indicator Lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Use a scan tool in order to clear the MIL and the DTC.
DIAGNOSTIC AIDS
Inspect for the following conditions:
The correct PCV valve, properly installed, and proper operation of the PCV valve
Proper operation and installation of all air intake components
Proper installation and operation of the mass air flow sensor, if equipped
A tampered with or damaged throttle stop screw
A tampered with or damaged throttle plate, throttle shaft, throttle linkage, or cruise control linkage, if equipped
A skewed high TP sensor
Excessive deposits in the IAC passage or on the IAC pintle
Excessive deposits in the throttle bore or on the throttle plate
Vacuum leaks
A high or unstable idle condition could be caused by a non-IAC system problem that cannot be overcome by the IAC valve. Refer to Symptoms - Computers and Control Systems. See: Computers and Control Systems > Symptom Related Diagnostic Procedures
If the problem is intermittent, refer to Intermittent Conditions in Symptoms. See: Computers and Control Systems > Initial Inspection and Diagnostic Overview > Intermittent Conditions
Oct 5, 2019 at 10:55 PM
YAIYR
  • 7 POSTS
ASEMASTER6371.
Thanks for the response maybe you can give me an explanation on what i did this morning i took my new IAC valve out and i adjusted my old valve to the furthest poin t pindel out and the car idled normal i put my new one back in and the rpm's was at 1,500 to 2,000. so i disconnected the IAC valve while the car was running when i observed the IAC valve it was still seated at the furthest point away from throttle body. so i removed the new one and with the old one i twisted in the pidel until it was seated at furthest point away from throttle body reconnected it for a minute to see if the PCM would command it to move out when i disconnected it while the car was running i saw that it had not moved from the seated position and the idle was high. so i twisted the old IAC back out to its furthest point close to the throttle body and connected it the idle is normal. i am thinking the PCM is not commanding the IAC not sure.
Oct 6, 2019 at 3:14 AM
I agree. The PCM commands the pindle retracted when you start and then extends it when the engine starts.
Do you have a scan tool to see if the PCM is commanding the valve? You can make it move in and out with bi directional commands with a scan tool.
Oct 6, 2019 at 3:28 AM
YAIYR
  • 7 POSTS
No, but im leaning toward my PCM it is a replacement, my old one went out on me about a month ago. problem started around the time i replaced it with this new one. it is all most inspection time so i am hoping that this little trick i did will keep the idle down until my i am ready is complete without those codes popping up then i can focus on the PCM and the problem.
Oct 6, 2019 at 4:01 AM
If you have it idling okay, the PCM will try commanding the valve to move. The code will return.
Oct 6, 2019 at 4:09 AM
YAIYR
  • 7 POSTS
It should but if the PCM is not responding to the IAC then it should remain in the position it is in. that is my theory. i am allowing the engine to cool down and see how it response to a cold start.
Oct 6, 2019 at 5:02 AM
Keep me updated.
Oct 6, 2019 at 5:14 AM
YAIYR
  • 7 POSTS
Okay.
Oct 6, 2019 at 5:32 AM
YAIYR
  • 7 POSTS
you were correct the rpm's raised and the car started coasting with out me accelerating and now there is a pending p0121. i pulled over put the car in park and the idle returned to normal. what are your thoughts?
Oct 6, 2019 at 5:38 AM
Did you check the connector for power at the IAC?
Do you have a scan tool that can read the voltage signal from the TPS?
Oct 6, 2019 at 5:39 AM
YAIYR
  • 7 POSTS
my scan tool shows the TPS at o in idle and increases as i step on the accelerator. the scan tool is basic.
Oct 6, 2019 at 5:49 AM
Okay, good.
I attached diagnostic aids for you to view.
DIAGNOSTIC AIDS
A skewed MAP signal -A skewed MAP signal may cause the PCM to incorrectly determine the TP sensor is out of range. Inspect for an unusually low or high MAP reading.
If the DTC is determined to be intermittent or if the TP sensor system is still suspect, refer to DTC P1121 and/or Symptoms - Computers and Control Systems. See: A L L Diagnostic Trouble Codes ( DTC ) > P Code Charts > P1121 See: Computers and Control Systems > Symptom Related Diagnostic Procedures
CIRCUIT DESCRIPTION
The Throttle Position (TP) sensor is used by the Powertrain Control Module (PCM) in order to determine the throttle plate angle for various engine management Systems. The TP sensor is a potentiometer type sensor with 3 circuits: the 5-volt reference circuit, the low reference circuit, and the signal circuit. Rotation of the TP sensor rotor from the closed throttle position to the Wide Open Throttle (WOT) position provides the PCM with a signal voltage from below 1 volt to greater than 4 volts through the TP sensor signal circuit. If the PCM detects an intermittent excessively high signal voltage, this DTC will set.
Oct 6, 2019 at 5:55 AM
