P0120 code
150,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
STARLORD1976
  • 173 POSTS
I keep getting a p0120 code. what is this and how to fix it?
Sep 24, 2019 at 3:24 AM
Good afternoon,
Can you verify the code? There is no 120 listed.
Sep 24, 2019 at 4:10 AM
STARLORD1976
  • 173 POSTS
P0121.
Sep 24, 2019 at 4:14 AM
Okay, this is for the TPS sensor voltage too low.
I attached the flow chart for you to follow to determine the failure.
Sep 24, 2019 at 5:07 AM
STARLORD1976
  • 173 POSTS
What does that mean a short in a wire or bad sensor?
Sep 24, 2019 at 5:11 AM
A short is 2 wires touching together that should not be touching.
A bad sensor is one of the sensors not registering correctly due to an internal failure.
Sep 24, 2019 at 5:14 AM
STARLORD1976
  • 173 POSTS
What does it mean if TPS voltage is too low then?
Sep 24, 2019 at 5:17 AM
The reading is not correct. that's why you need to follow the flow chart.
Sep 24, 2019 at 5:25 AM
