Code p0107
80,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROGERJRSS
When I start the car cold the RPM fluctuates and stalls. I got p0107 for the code. Could I have a diagram showing the location of the sensor that is defective? Thank you
Nov 11, 2018 at 10:45 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Code P0107 refers to Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage and here is where that map sensor is located.
And how to remove it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Nov 12, 2018 at 12:43 AM
DRAY_DALTON
How do I fix a po107 MAP/BARO Circuit Low Input for a 2000 Chevy Malibu with a 3.1L V6?
Jan 4, 2021 at 1:06 AM (Merged)
  • 75,988 POSTS
DTC P0107 The causes of a low MAP sensor signal circuit (P0107) could be any of the following:
Bad MAP sensor
Open or short in the signal circuit
Open or short in the 5 Volt reference circuit
Ground circuit open or shorted
Bad PCM
Possible SolutionsFirst, using a scan tool with the Key on and engine running, monitor the MAP sensor voltage. If it is reading less than .5 volts, turn engine off, unplug the MAP sensor and, using a DVOM (Digital Volt/Ohm Meter) check for 5Volts on the 5 Volt reference circuit.
1. If there is not 5 Volts on the reference circuit, then check for the reference voltage at the PCM connector. If it is present at the PCM connector but not the MAP connector, repair the open in the reference circuit between the PCM and MAP harness connector. If 5 Volt reference is NOT present at the PCM connector, check powers and grounds of PCM and repair/replace as needed. (NOTE: On Chrysler products, a shorted Crank sensor, Vehicle speed sensor or any other sensor that utilizes the 5 Volt reference from the PCM can short out the 5 Volt reference. To fix simply unplug each sensor one at a time until the 5 Volt reference reappears. The last sensor unplugged is the shorted sensor.)
2. If you have a 5 Volt reference at the MAP connector, jumper the 5 volt reference circuit to the signal circuit. Now check the MAP voltage on the scan tool. It should be 4.5 to 5 Volts. If it is, replace MAP sensor. If not, repair open/short in the signal circuit wiring and re-check.
3. If all appears okay, perform a wiggle test. Start engine and manipulate the harness, connector and tap on the MAP sensor. Note any changes in voltage or engine speed. Repair connector, harness, or sensor as needed.
4. If the wiggle test checks out, use a vacuum pump (or just use your lungs) to draw a vacuum on the MAP sensor vacuum port. As you add vacuum the voltage should decrease. With no vacuum, the MAP sensor should read approximately 4.5 volts. If there is no change in MAP sensor reading on the scan tool, replace MAP sensor.
