Check engine light is not showing on dash only comes up when I plug in scanner. Replaced the mass air flow w/ OEM, new air filter, changed out O2 sensor (again OEM) in Bank 1 and have replace upper air intake tube which did have a crack in it. I also have looked for cracked hoses/ vacuum leaks. I don't know what else to do. Car is starting fine but when pressing the gas pedal while driving i can feel a slight hesitation/surge. Sometimes when I'm at a red light its idle is so low i feel as though it may shut off but never has yet. I don't know what else to do or check for. Lost my husband 7 years ago who was our mechanic and funds are limited, so a ginormous repair bill is not in my budget. I do plan on tuning it up soon but I'm not sure if that would help at all. Thank you in advance for any answers or guidance with this car.
Oct 6, 2022 at 7:22 AM
