p0100 code
2006 CHEVROLET IMPALA
125,000 MILES
CABBY022
  • 6 POSTS
replaced mass air flow assembly, with new air filter, checked for vacuum leaks, ( none) when i clear code car runs without engine light on, once car is shutt off and restarted engine light appears p0100. any ideas? mike
Apr 27, 2013 at 2:33 AM
WRENCHTECH
  • 20,761 POSTS
The reason it acts that way is because it is a 2 trip code. Apparently the sensor itself was not the problem and it needs to be troubleshooted further. Could be wiring, PCM or a mechanical air flow issue in the engine.
Apr 27, 2013 at 2:59 AM
CABBY022
  • 6 POSTS
ok thanks i will check the wiring harness
Apr 27, 2013 at 3:50 AM
