Code P0090, full interpretation?
124,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
ABAYA
  • 77 POSTS
After replacement of the fuel regulator, the engine won't accelerate.
Jan 24, 2025 at 12:47 AM
  • 55,649 POSTS
Yep, it looks like you have defective part or the electrical connector or is not on completely or there is a bad connection and the regulator.
P0090 - Fuel Pressure Regulator Control Circuit Open
Here is the correct way to replace the part and its location for clarity. Check out the images (below). Please let us know what happens. Clear the codes once completed.
Jan 24, 2025 at 3:10 AM
ABAYA
  • 77 POSTS
If the DTC P0090 concern fuel pressure regulator control circuit open. Why does I repair the pressure sensor connector? Is it not the regular connector who must be repaired? Please excuse my understanding. Thank you very much.
Jan 26, 2025 at 2:27 AM
  • 55,649 POSTS
Did you see the images above, is this the part you replaced?
Jan 27, 2025 at 1:15 AM
ABAYA
  • 77 POSTS
The fuel pressure sensor in my car is placed on the common rail. It had 3 wires. The part I replaced is the fuel pressure regulator which is mounted on the high pressure pump.
Thank you Mr. Ken.
Jan 27, 2025 at 2:04 AM
  • 55,649 POSTS
I would check the high-pressure pump camshaft lobe. These have a tenancy to wear down which will make the engine have no power. Can I ask why you replaced the regulator? Was it because of the code? Check out the images (below). Please let us know what happens.
Jan 28, 2025 at 1:30 AM
ABAYA
  • 77 POSTS
Hi, yes sir, it was helpfull.
Jan 28, 2025 at 4:32 PM
  • 55,649 POSTS
So is the problem fixed or are you still working on it?
Jan 29, 2025 at 12:42 AM
ABAYA
  • 77 POSTS
Yes for the dtc P0090. Thank you Mr. Ken.
Now, remain the dtc P0089. Please help me to resolve it.
Jan 29, 2025 at 4:08 AM
  • 55,649 POSTS
Can I ask what fixed the Code P0090?
Jan 30, 2025 at 3:52 AM
