p0035 code
2003 SATURN VUE
176,000 MILES • 3.0L • 6 CYL • AWD • AUTOMATIC
GRANDMAOFABZ
  • 19 POSTS
Dies after engine warms up ( three to five miles of driving) it does start again after around fifteen minutes of cooling off, but it will die again within three to five miles, p0035 was the code given by dealership. Symptoms are horrible gas mileage (13 mpg) check engine light does not always come on. There were a few incidences where it would start, die immediately and would not start again until next day and or after having it towed (this only occurs if it starts and immediately dies). The timing belt and the sensor near it have recently been replaced, my research brought me to the mass air flow sensor, or could it be a module on top of the engine as I was told? Said code was for turbo and mine is not.
May 22, 2016 at 11:50 PM
SATURNTECH9
  • 30,869 POSTS
Are you sure the code isn't p0335 ?Sounds like a bad crankshaft position sensor causing the firing then cooling down and restarting really common on those.
May 23, 2016 at 3:22 AM
GRANDMAOFABZ
  • 19 POSTS
Positive. paperwork says p0035. The crank shaft sensor was replaced with the timing belt less than 15,000 miles ago.
May 23, 2016 at 4:42 AM
GRANDMAOFABZ
  • 19 POSTS
Positive. paperwork says p0035. The cr. shaft sensor was replaced with the timing belt less than 15k miles ago.
May 23, 2016 at 4:45 AM
SATURNTECH9
  • 30,869 POSTS
I cannot find that code listed for that car, do they have free code reads in your state?Also the squeaking in the steering wheel is probably the boot that goes at the base of your steering column inside.
May 23, 2016 at 5:17 AM
GRANDMAOFABZ
  • 19 POSTS
Problem is getting it to the parts store Weird you cannot find the code, a dealership took the reading. I used to be able to drive fifteen plus miles before it would die. Now it is a matter of blocks, it has progressively gotten worse I just cannot afford the $250.00 they want to diagnosis further. I have spent hours searching and find the symptoms fit those caused by a bad mass air flow sensor I just want to be positive before I spend the $100.00 plus the $75.00 for the core, to find out it was a bad gas cap. I thank you deeply for your time as do my granddaughters as it is their birthday budgets I have to dip into.
May 23, 2016 at 5:29 AM
SATURNTECH9
  • 30,869 POSTS
The dealer could have wrote down the wrong code it happens.So it is a 2003 Saturn v6 engine Vue for sure?
May 23, 2016 at 5:31 AM
SATURNTECH9
  • 30,869 POSTS
I high doubt it is the gas cap when it wont start, but remove the cap and see if it starts?
May 23, 2016 at 5:34 AM
GRANDMAOFABZ
  • 19 POSTS
I think it is a straight 6 the v6 is the turbo. Mine is 3.0 for sure.
May 23, 2016 at 5:35 AM
SATURNTECH9
  • 30,869 POSTS
I have a factory Vue service manual from when I went through Vue factory training I will try to look the code up in there.
SATURNTECH9
  • 30,869 POSTS
There never was a straight 6 or turbo for Vue I would know if there wa.s
May 23, 2016 at 5:37 AM
GRANDMAOFABZ
  • 19 POSTS
I am going to try to make it to parts store it is only four blocks, I will let you know outcome when I return. Fingers crossed it does not die in middle of intersection. Talk to you soon. Thanks.
May 23, 2016 at 5:38 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome keep me posted and write down the number not the description.
May 23, 2016 at 5:41 AM
GRANDMAOFABZ
  • 19 POSTS
I just saw options for the 6 cylinder, I am confused now, one option was V6, 3.1? The other was 6/3.0 ? But I am sure it is 3.0 says it on the engine cover,
SATURNTECH9
  • 30,869 POSTS
If it is a v6 it is the 3.0L that is the only one they had for those.
May 23, 2016 at 5:55 AM
GRANDMAOFABZ
  • 19 POSTS
I did not like the service at that dealership, and now even more so, you were right, the code is p0335, I am going to check for faulty wiring as it was just replaced as I mentioned at 15,000 miles ago, otherwise new sensor here I come. Thank you so much.
May 23, 2016 at 6:06 AM
SATURNTECH9
  • 30,869 POSTS
With heating up and cooling down and working it is most likely a bad crankshaft position sensor.Your welcome I am here to help.
May 23, 2016 at 6:09 AM
GRANDMAOFABZ
  • 19 POSTS
Is this why I am getting such bad gas mileage? I have kept track and 13/14 mpg is what I am getting, of everything I have read 23 to 28 mpg should be the numbers,
May 23, 2016 at 6:29 AM
SATURNTECH9
  • 30,869 POSTS
Not from a bad crankshaft position sensor that will just shut the engine off when it fails. Getting it running again and see what happens with codes etc.
May 23, 2016 at 11:33 AM
GRANDMAOFABZ
  • 19 POSTS
Hello, finally received sensor, easily replaced it, she turns over but won't start, Ck eng light came on after 3rd try, is there anyway to reset values without a code reader
Jun 14, 2016 at 5:27 PM
SATURNTECH9
  • 30,869 POSTS
It should start right up after replacing it.CAn you post a picture of the old one you replaced?
Jun 14, 2016 at 11:46 PM
GRANDMAOFABZ
  • 19 POSTS
I did notice the wires going I to the plug seemed flimsy
Jun 15, 2016 at 1:00 AM
SATURNTECH9
  • 30,869 POSTS
Did it started run before you changed it?if so put the old one back in and see if it starts?Maybe you ggot a new bad one?That happens and it will throw you off when it does happen.
Jun 15, 2016 at 5:21 AM
GRANDMAOFABZ
  • 19 POSTS
I'll try that I'll let you know tomorrow if it worked. Thanks
Jun 15, 2016 at 6:12 AM
GRANDMAOFABZ
  • 19 POSTS
Yep, it was a faulty new part, THANK YOU for being so prompt a D helpful.
Jun 15, 2016 at 7:19 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome had a feeling it was
Jun 15, 2016 at 1:13 PM
