p0022 code, now I need a new engine
88,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
WEBIDIS
My truck started hesitating then would shut off at stop signs and lights. I bought an ODB II code reader and got code p0022. Did the research and replaced both vct solenoids. The check engine stayed on so I reset it and the truck ran fine for 18 or so miles and check engine came on and it started up all over again. Did some more research and learned that it could be the oil pump or the cam phasers. Took it to my mechanic and he basically gave up saying to many things could be wrong with it and he was swamped with work. He suggested I take it to the dealer. During my research I noticed that by taking the truck to the dealer would result in being told that I needed a new engine. Took it to the dealer which ran their own diagnostic which resulted in the same code I knew the truck had. Then the oil pressure test was good, I as told. Before all this they wanted to take the vct solenoids out to check for metal. But since I had replaced both of them and didn't notice any metal on the vct's they didn't remove them. Then I received a call telling me that the camshaft looked scored and had large scrapes. This according to the dealership caused a lost in pressure and could be causing the problem. I knew taking it to the dealer would result in a engine rebuild or an engine swap. This seemed to be the theme as I read thru the threads. My question is does the camshaft having scrapes enough to cause code p0022 and the symptoms my truck is suffering from?
Sep 30, 2014 at 10:29 PM
HMAC300
  • 48,601 POSTS
best thing here is to take valve covers off and look at cams if metal went through they will be screwed up. remove the solenoids and see if ther eis any junk around them if any oil holes clean them out. you have nothing to lose anyhow except time. It cold be sludge as well.if it goes away change oil an dfilter and put a good filter on in like Purolator, wix, napa etc.
Sep 30, 2014 at 11:40 PM
WEBIDIS
Had that done. No sludge. The dealership claims that a piece of metal has broken off someplace in the engine. That that piece of metal has scraped the camshaft and may still be in the engine. They wont guarantee that the cam phaser replacement will fix the situation due to that piece of metal supposedly floating around the engine. I'd figure it would end up in the oil pan or if large enough get caught somewhere. I am being quoted over $ 7000.00 for a engine replacement. Only at 88,000 miles.
Oct 1, 2014 at 12:22 AM
HMAC300
  • 48,601 POSTS
normally metal gets caught in two places the lifter valley which yours doesn't have and the pan or filter. I'd check around for other places like a junkyard for a motor. the sad part is one mileage on motor, an d if you replace the engine and still have the code which could mean a bad pcm or shorted wire you would still have it. having worked in dealers prior I know they won't guarantee that for a fix either.
Oct 1, 2014 at 5:17 AM
