Hi, I did a timing chain on an Audi 3.2. Did leak down test before reassembly and no leak down and lobes were pointed correctly, I also had timing kit installed to lock. The engine was out of time on the 2nd bank, one tooth. Rotated engine marks lined back up. Reinstalled engine. P0018 and p0019 come up. (These were the codes to begin with.) Verified it was out of time, engine is in time, verified with leak down test, going to compression test it tomorrow, but is there anything else that can cause this? I believe the VVT are new too, not sure if off brand though. Also, has a secondary air fault code.
Oct 5, 2022 at 3:05 PM
