Code P0014?
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
EGUNS80
  • 85 POSTS
I have a p0014 code, that says camshaft position sensor bank 1, where is that sensor located?
Aug 18, 2025 at 11:30 PM
  • 55,604 POSTS
So this code may not mean the sensor is bad. It means the timing chain components needs to be replaced, such as the timing chain, guides, tensioner and camshaft actuators. But this can be an oil control valve stuck open as well. Here is the location of the valves if you want to change them out which might work.
P0014 - Exhaust Camshaft Position Timing Over-Advanced (Bank 1)
Here is an image of what needs to be replaced, and I have included the location for the sensor if you want to give it a shot. Be sure to clear the codes after the replacement. There are tow sensors. Check out the images (below). Let us know how it goes
Aug 20, 2025 at 3:52 AM
EGUNS80
  • 85 POSTS
I read that it could also be just an oil change is that possible?
Aug 20, 2025 at 6:04 AM
  • 55,604 POSTS
That may help, but I have seen it help the Over-Advanced code but you never know. Let me know what happens so I can help as needed.
Aug 20, 2025 at 6:18 AM
