My car is running weird and knocking..brought it to Autozone and scanned it and these numbers pop up p000b, p0024, p033, p0328.
Feb 11, 2017 at 7:01 AM
HMAC300
✓Experienced Mechanic
the first two deal with exhaust cam performance response so it may be low oil pressure, a bad cam phaser plugged screens or oil leakage at cam actuator solenoid. also maybe a stretched timing chain. there is no code 33 it's either 31 or 32 and that is an O2 sensor problem bank 1 sensor 1 328 is a knock sensor code so you said you have a knock find the cause and that may go away.
