Car is not running right many codes came up
JR ESCAMILLA
  • 2010 GMC
  • 122,697 MILES
My car is running weird and knocking. Brought it to Autozone and scanned it and these numbers pop up p000b, p0024, p033, p0328.
Saturday, February 11th, 2017 AT 3:01 PM
HMAC300
  • 48,601 POSTS
The first two deal with exhaust cam performance response so it may be low oil pressure, a bad cam phaser plugged screens or oil leakage at cam actuator solenoid. Also maybe a stretched timing chain. There is no code 33 it's either 31 or 32 and that is an O2 sensor problem bank 1 sensor 1 328 is a knock sensor code so you said you have a knock find the cause and that may go away.
Saturday, February 11th, 2017 AT 3:40 PM
