Codes p2187 and p2187?
2007 HYUNDAI SONATA
257,565 MILES • AUTOMATIC
AHORN31
i have cylinder 1 misfire and i also have an issue with my car running lean. codes p0301 and code p2187. Is it possible that the code p2187 is causing the other code to pop up because there's not enough fuel air ration?
Jan 26, 2023 at 3:07 AM
  • 110,241 POSTS
If there is a lean fuel mixture, yes it can cause a misfire and other drivability issues as well. I will need to know if this has a 4 or 6 cylinder engine.
The idea of a lean fuel mixture usually results from one of two things, an engine vacuum leak or low fuel pressure.
With that in mind, the first thing I suggest is to check for engine vacuum leaks. It isn't uncommon for hoses to come disconnected or gaskets to fail allowing unmetered air to enter the engine. Also, hoses can break or dry rot causing a leak.
Here is a link that explains how to locate and repair an engine vacuum leak:
If you are unable to locate any leaks, next I would suggest checking the fuel pressure.
Here is a link that explains in general how that is done:
Let me know if you are comfortable performing these tests or if you have other questions.
Jan 26, 2023 at 7:08 AM
