Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Santa Fe
Steering
Pump
Replace/Remove
Power steering pump removal
2009 HYUNDAI SANTA FE
150,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DILL-11
MEMBER
how do I get the high pressure line off the pump?
May 22, 2017 at 9:40 PM
HMAC300
Experienced Mechanic
see pictures. you will need line wrenches to loosen at rack/pinion and need to take off bracket bolts to remove the line. do not lose the washers that attach to pump they are for sealing and if you lose them it will not seal.
Images (Click to enlarge)
May 22, 2017 at 10:48 PM
Add image or video
Ask a new question
Check engine light
Engine won't start
