My car has 1300 code 300 code 340. what parts do i need to fix code my car and get the engine light to come off?
Oct 25, 2016 at 10:07 AM
JIS001
✓Experienced Mechanic
Make sure spark plugs are good. Would strongly recommend you put on dealer spark plugs if problem started after replacing. For the P0340 you will most likely need to replace the ignition coil cassette.
