Codes P0017 and P0023
130,000 MILES
ARMANDO ORTEGA
  • 6 POSTS
My engine was fixed. I believe they played with the timing chain and now I have those two codes.
Aug 18, 2021 at 1:32 AM
Good afternoon,
What was repaired on the engine? Please give me the details.
Both codes are related to the timing chain.
Aug 18, 2021 at 3:06 AM
ARMANDO ORTEGA
  • 6 POSTS
They replaced the valves.
Aug 18, 2021 at 5:51 AM
Okay, thank you.
They have the timing chain on wrong.
Return the car to the repair shop and have them set the timing correctly.
I attached a diagram of the lower chain that is most likely the issue.
I attached a YouTube video of the procedure for you.
https://www.youtube.com/watch?v=BhDs1GcwRCs
Aug 18, 2021 at 6:14 AM
ARMANDO ORTEGA
  • 6 POSTS
Because it lost compression.
Aug 18, 2021 at 6:21 AM
ARMANDO ORTEGA
  • 6 POSTS
Thanks.
Aug 18, 2021 at 6:23 AM
You are welcome.
Always glad to help.
Aug 18, 2021 at 6:29 AM
ARMANDO ORTEGA
  • 6 POSTS
Replacing the camshaft position sensor and crankshaft position sensor could be a solution?
Aug 18, 2021 at 6:30 AM
No, not at all. The timing is incorrect. The sensors just send a signal to the ECM. They have nothing to do with adjusting the timing.
Aug 18, 2021 at 6:35 AM
ARMANDO ORTEGA
  • 6 POSTS
Okay, thanks.
Aug 18, 2021 at 9:27 AM
You are welcome.
Aug 18, 2021 at 9:36 AM
