Oxygen sensors, coil pack code
245,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
04MUSTANGGT
Hi, my truck won't read the afr on any of my o2 sensors. It also won't read my one coil even though all of the plugs and coils are new, and I swapped the coils to that cylinder and it still won't read.
Apr 15, 2020 at 5:53 AM
Just so I understand the issue, you have codes for the o2 sensor and coils? If you do have codes, what are the actual codes? When you are saying they are not reading, I am not sure what you are referring to so if you have codes, just send those over and we can go from there. Thanks
Apr 15, 2020 at 7:29 AM
