I can't locate the downstream sensor harness wire under truck.
Dec 9, 2023 at 6:22 AM
✓Experienced Mechanic
Was it connected before working on the vehicle? Also, on some sensors, the wiring is connected to it from the factory and the connector is in the engine compartment.
Dec 9, 2023 at 3:00 PM
LEVELTWO
MEMBER
It seems as if there was no downstream oxygen sensor, or downstream harness wire.
Dec 11, 2023 at 4:43 AM
Check behind the engine to see if anything is disconnected. I'm not sure what someone has done. The wiring from the sensor goes in different directions, so there has to be a connector at some point.
I attached a pic below at least showing the wire colors you should be looking for at a connector. It should be a round connector with 4 pins.
