oxygen sensor where is bank 2, sensor located?
110,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
PHILBJAH
where is the bank 2, sensor 1 located?
Apr 23, 2025 at 2:54 AM
  • 55,512 POSTS
Bank 2 of the engine is closest to the radiator. It will be the first oxygen sensor in the exhaust system. Here is a guide to walk you through the step of changing it out correctly:
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Check out the images (below). Let us know if you need anything else.
Apr 23, 2025 at 4:29 AM
