The idle goes up and down and I have to floor it to get going, it wants to die.
Jun 25, 2016 at 4:52 AM
JDL
✓Experienced Mechanic
I have to ask, how long since a tune-up? 02 sensors are part of a tune-up. Are there any applicable trouble codes? Usually with any idle issues, I want to clean the throttle-body, check and clean anything that has to do with idle air system.
The generic basics for a rough idle is to check for a leak of some kind, fuel--egr--vacuum leak.
Jun 25, 2016 at 5:18 AM
CURT SMITH2
MEMBER
Auto zone did not have hook up the flash code was 44 that is where I got o2 sensor. Where is it at?
Jun 25, 2016 at 6:58 AM
Hey Curt,
It sounds like you have a vacuum leak, and a weak fuel pump, or a plugged fuel filter.
