About 1 1/2 years ago, the check engine light came on. Code read that the heater was open on the oxygen sensor (the one on the front of the engine). I replaced it with a generic sensor that was fine for almost a year. Check engine light came on again, mostly code P2240. Erased code, then was intermittent-no pattern. Occasionally code was P0174. Replace sensor with correct OEM sensor. Was ok for 3 days, then check engine light came on, code P0154. Put generic sensor back in. Back to code P2240. Van starts, runs fine.
Nov 13, 2023 at 3:27 AM
